Old Jan 7, 2017 | 12:51 PM
Yumu1009's Avatar
Yumu1009
Default Re: Supercharger Pulleys
Originally Posted by Zoodust
You will run more danger then just running a single 62 or 185..You will need more cooling, and fuel, and exact tuning for the kind of boost a stacked setup will give you. Depending on your altitude matters a lot as well. Closer to sea level will see the most boost. You don't want to overboost that Blower. Don't forget that engine is now going on 12 years old. If you wanna make that power do it right and spend the $$ on support mods. There is a member here who made a huge writeup about his mods with his stacked setup. Look up Boostmonkey
So running the staked pulley's will obviously allow more boost but do you have an estimate of around how much PSI? Also is there anyway to adjust boost? Like a wastegate?
