Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Jan 7, 2017 | 08:55 PM
1001
permalink
kimkeach
Jan 2017
Jacksonville, FL
Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Quote:
drhrsh
A lot has been written on this site about this problem. I was having the problem of the key not turning, and having to try 6 or more times turning the steering wheel, etc. until it finally worked. I also read about others who were finally unable to turn the key at all, requiring a tow to the dealer and a bill for $1500.00 or more to fix. I want to thank Crossbow 39 for his nice thread on how to do this. I am a visual guy and thought I would take pictures and post a thread to help others. I also learned a few tips which may help others.
1.) Disconnect the negative battery terminal.
2.) Remove the fuse panel access door to the left of the steering wheel, in the door jam area.
3.) Remove the air vent above the headlight switch. It just pops out.
4.) Remove the lower trim panels. First remove the "U" shaped panel below the steering wheel (one screw). This gives you access to 2 hidden screws which need to be removed.
UPDATE
NEWEST PDF FILE AS OF JUNE 1 , 2013
The new PDF is
version 5
Thank you, thank you, thank you!!! I cannot tell you how much I appreciate these very detailed, awesome instructions and pictures!!! I was able to successfully complete this by myself, with your PDF file and you saved me big time as I do NOT have the money to take my car to anyone else to fix right now! I so very much appreciate the time and effort that you put into making this fix available to everyone in such an easy to read/understand format! Hats off to you!!! Thanks again!!!
kimkeach
View Public Profile
Find all posts by kimkeach
