RKC00
RE: 2005 SRT6. I'm replacing all brakes and rotors. Rears were no problem. When I removed the front caliper and compressed the first puck the other puck extended. Now I cannot get it to compress. I took the caliper off so I can get to everything and still, even with a pipe compression clamp I cannot get it to budge. I know some Mercedes require the puck to be rotated so I rotated the one on the SRT6 and still no luck. I'm sure there's an expert on here who has the solution. Old Dog, new toy. I appreciate any insight.
Is it possible that you have not applied the pressure down the center line of the piston and have forced the piston off center and jammed the bottom edge of the piston into the cylinder wall. More pressure will then just wedge it even further.
Try and apply some pressure on the inside face of the piston maybe that will get it back in line.. If that is the case you should look for damage on the cylinder and piston.
