Old Jan 29, 2017 | 06:11 PM
onehundred80
Default Re: Car not starting
Originally Posted by andrew267
Hi I have 2009 softtop and it has just died, the car turns on but wont start and the wing will not retract even using the manual overide. Radio lights etc all work but the car wont start any ideas?
New battery put in 3month ago and fill service a few weeks ago.
Thanks for any help
Andrew
Have you had the battery tested, even new batteries can die prematurely.
Also check battery connections and grounding of it.
Do you hear any sound when you turn the key?
The wing getting deployed is normally a sign of low voltage in the system.
