sunsetseeker
I might be getting closer to the battery drain problem. The radio fuse eliminates the excess amps. I have temporarily removed the fuse to see if that helps. I did put a CD in the slot and it got stuck. I'm guessing it continually tries to either load or eject it causing the drain. Now I need to figure out how to get the disc out.....
I really appreciate all the help!!
Gary
You are welcome.
Want some more advice ?
Junk the OEM radio and get something more modern with USB/MP3 and BlueTooth.
( Hint : look at the Marine radios, many are silver and almost match )
for $40 from amazon, this one seems to fit the bill :
https://www.amazon.com/Lanzar-AQMP70...=marine+radios
or if you don't need the cd player, many chose this one ( the center spine even blends in ) :
https://www.amazon.com/Clarion-Corpo...=marine+radios
