Old Feb 10, 2017 | 10:30 AM
  #147 (permalink)
ala_xfire
Default Re: N/A 74mm Throttle Body Upgrade Guide
Originally Posted by zip439
180 question: with your setup what is the temperature of the intake air? I have a single Needswings CAI, using an Ultragauge and at cruising speed my intake temperature is about 3 or 4 degrees F above ambient, but it does increase while at a signal light. Have you measured yours?
I agree Steve, but ONLY if the ambient is below 50 F.
When it gets HOT ( 80 - 95 F ), I see up to 25 F higher IAT than ambient while cruising.
When I go up a hill, the IAT drops 2 or 3 degrees due to the increased airflow, but it also increases when I go down a hill.
