Old Feb 10, 2017 | 01:28 PM
  #150 (permalink)
Speedy4x4's Avatar
Speedy4x4
Default
Originally Posted by kamilspider
I know that we only put old MAF sensor to new bigger 74mm MAF housing.
Normaly old MAF sensor is designed to 68mm diameter. Physically fit to bigger 74mm. But if we put it to 74mm diameter I think that he give not correct infos to ECU.
I not know how explain it. ECU not know that we change diameter. Old MAF sensor/ECU think that measure air flow in 68mm all the time.
I know what you mean, the engine is getting more air that the maf sensor is saying it is getting.
I ran mine for quite awhile with the 74mm sensor installed, honestly I do not remember if I changed it to the 68mm sensor in the 74mm housing or left the 74mm sensor in the 74mm housing, I will check on that later.
Agreed, but I did see a slight increase in MPG, which is always a good thing.
Huh, I got less mpg
