Old Feb 11, 2017 | 08:53 PM
jmh's Avatar
jmh
Default Re: Car not starting
Originally Posted by andrew267
I have not had the batery tested, also the car makes a low whining/screeching sound (best I can describe it) when I turn the ignition key.
I will get the battery tested and look at the connections.
Thanks for you help
If your battery checks out or you replace it and it's still doing the same thing maybe the starter gears not engaging the flywheel? Might be a bad solenoid that's not able to push the starter gear out far enough? Just a guess here.
