Old Feb 15, 2017 | 05:08 PM
onehundred80
Default Re: Rocker panel and jack pad removal question
Originally Posted by performanceisland
Does anyone know how to remove the plastic jack pads underneath the vehicle to be able to remove the rocker panel (side skirts)? it looks like there is a slit in the middle for a flat screwdriver, but it won't unscrew, I am assuming you have to find the right position for tabs to release or something along those lines? any help from someone that has removed them in the past would be appreciated, thanks.
I took a couple out and it took some time to find out how.
The secret is to lightly pry the pad toward the ground while unscrewing the screw. This action starts the screwed end of the screw into the threaded hole in the pad. It is quite an ingenious assembly. You need a nice wide tool as the screwdriver or it gets too awkward to do.
