Old Feb 16, 2017 | 12:25 PM
onehundred80
Default Re: blinking fuel light check engine
Originally Posted by Jjtow007
I don't ever try to get more gas in incentive full, and rarely full it all the way up either-it's probably been a month or two since I filled the tank completely full... thanks for the PDF though, informative! Have the selenoid (the parts store called it a canister purge valve) ordered-will try that Monday.. I am thinking that that is what it is, because when I found it on mounted – when this problem started a couple of days ago – it didn't correct the problem for a little bit to remount it… Plus from what I understand there is only one other thing to try – and that's $450 – the vaper tank itself..I have already replaced the gas cap as well as put some seafoam in the tank… from what I understand it does not hurt it to drive it like this? I have to have that check engine light off though, I need to have my car inspected in the next couple of days.also I have a headlight out, and it's not the headlight lamp that it's got to be the wiring as I don't have power to the low beam on the left side so I have to have both of these issues resolved to have it inspected so that I can renew my tag by the end of this month, so I'm running out of time
Vapour tank on eBay - $40 including solenoid. CLICK
