Old Feb 18, 2017 | 09:35 PM
  #1011 (permalink)
onehundred80
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by KDW4Him
Do you have the PDF and see those pictures? If you are one of the unlucky ones and it is locked up then you have to drill out the retaining pin (step 16 in the PDF) to pull the assy out of the steering column. Then you can remove the pin and spring.
The pin is best removed by grinding at it with a Dremel.
