Old Feb 21, 2017 | 06:40 PM
onehundred80
Default Re: Oil drain plug removal
Originally Posted by Steve Jr
Drain plug has a metal ring. 3should fit on the filter housing an 1 can be used on the dipstick.
The filters I use are Manns and they came with five O-rings, you use four on the filter housing. That leaves one spare.
The biggest problem is when the largest O-ring is positioned wrongly in the upper most groove which actually is just a relief for the thread. What happens then is oil leaking all over the engine.
