Old Feb 23, 2017 | 07:44 AM
  #38 (permalink)
Speedy4x4's Avatar
Speedy4x4
Default
Originally Posted by Gtsman
I have ran these sizes without using spacers without issues. You will need to find out the hub size of the wheel and possibly will need Hubsentric rings. You will probably need new lugs depending on the type of lug the rim uses and thickness of lug area of the rim. I ran stock tire sizes and no rubbing at all. It did push my front tire out almost even with front fender outside edge, but no issues. Hope this helps.
Stock front 32, sr08- 30
Stock rear 25, sr08- 22
5x112 uses conical ball lugs only, if they are drilled in a taper, then that is a fubar.
Yes most likely they have the 72 or 73 mm hub, going to check today when I call them. So I can get the metal hub ring.
Checking if they stuck out to far.
These are supposed to be stronger and lighter than our oem.
Guess on bolts, I will just have to wait till they come in and measure bolts, if mine are to long, I can cut them down till new bolts get in, want locking bolts.
What kind of rims did you use with 19x10.5 & 18x8.5 ?
Options are limited.
