Thread: Sticky ignition
Old Feb 27, 2017 | 05:17 PM
  #57 (permalink)
onehundred80
Default Re: Sticky ignition
Originally Posted by Whitcat9
Question; I'm about to install new ignition housing. Do I need to remove locking pin and/or the spring and pin under metal tab before installing? Thank you for your help.
If this is a newer part it should be no trouble as the later ones did not have the pin under the little plate that caused all the trouble. To be on the safe side you could remove the little plate and see that there is nothing there.
