Old Mar 13, 2017 | 08:15 AM
onehundred80
Default Re: After winter time no start
Originally Posted by danulah
This sensor i change last year diagnostic without any fault
The CPS used should be a Bosch part, the others have proven to be not so reliable.
Remove the connector from the CPS and make sure that it is not corroded, some of the other CPS makes have smaller pins and do not fit the socket too well and cause a bad connection.
The CPS does not move and many feel it should not fail. Check that connection.
