onehundred80
The CPS used should be a Bosch part, the others have proven to be not so reliable.
Remove the connector from the CPS and make sure that it is not corroded, some of the other CPS makes have smaller pins and do not fit the socket too well and cause a bad connection.
The CPS does not move and many feel it should not fail. Check that connection.
Agreed, I believe my connector worked loose a little, after CPS replacement, because I broke it's outside retaining clip. I secured it after that. Maybe failure heat related? Maybe magnetism weakens over time/use? Just guessing. I think he's saying no spark condition.
