Old Mar 16, 2017 | 10:05 AM
onehundred80
Default Re: After winter time no start
Originally Posted by danulah
I change new CPS form Bosch,new battery but everything is same.
Engine only spin but no ignition. Spark plugs are ok and doing spark.
Another idea ??? THX
Can you pull a spark plug and see if it wet from gasoline. Sparks and gas may not start an engine but there should be a noise of some form.
If the system says it is OK to spark I think it may feel it OK to inject gasoline.
No gasoline may point to the fuel system being at fault.
Can you hear the fuel pump when you turn the key to the accessory position?
If not there lies the problem, pump or fuse maybe, fuel filter?
