So here is where I am.
I put the top down manually. When I tried to put the top up with the switch, it sat for a second and did nothing but it started to move. The hatch opened and the top started to move a bit and then stopped. I could hear the pump.
I let go of the switch and then hit it again and again it moved up slightly and stopped. I repeated this a few times until the top came up about 3/4 and then nothing more. I was able to get the top manually to close. It felt like it was low on fluid so that would've been my next check but, I now can't lift the rear bow high enough to close the hatch.
I'm stuck at the point in the picture.
The button now blinks when the car is started. It stays lit when the car is off.
This top is not long for this car as it is but I would really like to get it operational before having to deal with a replacement.
I now get nothing from the switch. No movement and no sound.
Thanks for all your help.
