Re: Convertible top won't open :(
Update.
I went back out after letting it sit for a little while and the tonneau cover had relaxed and it was sitting on the rear window. I had put a blanket over the rear window just in case.
I was able to lift the rear bow up and put the tonneau down.
I then hit the button and the rear of the top latched down.
BUT, I cannot unlock the truck now. I can hear a little hum when I hit the unlock but it will not unlatch.
I've read posts where they say you can get to the mechanism through the drivers side license plate bulb assembly? I pulled the bulb assembly out and reached in but have no idea what I should be feeling for. Is it the drivers side assembly or the passenger side? EDIT: Ok, after some more reading, it sounds like if I go in through the passenger side, I should be trying to hook the emergency release cable and if I go in through the right side, a screwdriver is used to push the lock to the right. Do I have that right?
The saga continues...
Again, thank you for any advice you are able to supply. I really appreciate it.
Daryll
