Old Mar 20, 2017 | 06:25 PM
WingMan's Avatar
WingMan
Default Re: Pulled the fuse for the alarm - will this be a problem
I say again, due to this comment, I suggest you check if water has intruded into the right rear of the rear under the foam. It is a recurring problem when water intrudes into the modules located there from a couple of documented sources. IT DOES NOT HURT TO CHECK/ELIMINATE this common problem.
Thank you, GG! I'll look into this as well.
