Old Mar 21, 2017 | 07:22 AM
Hankdog's Avatar
Hankdog
Default Re: Parking light bulb replacement help.
Ohi p, they are a pain.
I used a long hemostat and a pair of extra-long bent needle nose pliers.
Turn 90 degrees counter-clockwise and pull out.
I never got the full 90 degrees on the re-install. Maybe 75 degrees.
The shop manual says to remove the whole lamp cluster. Quite a bit more involved.
I uses a 10 mm combination wrench. I put the open end on the bulb holder and turned it with a screwdriver in the boxed end
