Old Mar 21, 2017 | 01:15 PM
GraphiteGhost
Default Re: Parking light bulb replacement help
Originally Posted by Hankdog
I uses a 10 mm combination wrench. I put the open end on the bulb holder and turned it with a screwdriver in the boxed end
Roger that, my method also. Works fine, but still not easy.
And when you use the 10mm OE/BX wrench to take it out, apply a LIGHT coating of petroleum jelly on the lugs and gasket. This step helps the reinstall IMMENSELY. Otherwise, it is a $@%&# to turn to the lug stops.
