Old Mar 26, 2017 | 07:50 PM
onehundred80
Default Re: Replaceing skreem and ring
Originally Posted by fastfred
So I have a BAD SKEEM I hooked up my old one and fob works fine and key now turns on fine ....all that work ��....have to call rob at needswings and see what's up??????
The SKREEM does not determine if the key turns or not. I would suggest that you have put something back correctly this time that you did not do the previous time.
I believe that when the key is pushed fully a lock that prevents turning the key and the steering wheel lock is unlocked. Perhaps you did not connect that mechanism correctly. It is underneath the ignition switch and can be seen in the Sticky Key Fix. CLICK
