Old Mar 26, 2017 | 08:03 PM
fastfred's Avatar
fastfred
Default Re: Replaceing skreem and ring
The SKREEM does not determine if the key turns or not. I would suggest that you have put something back correctly this time that you did not do the previous time.
I believe that when the key is pushed fully a lock that prevents turning the key and the steering wheel lock is unlocked. Perhaps you did not connect that mechanism correctly. It is underneath the ignition switch and can be seen in the Sticky Key Fix. CLICK
Well you could be right as most of the time you are but I did use the sticky write up to help me take things down to that point ... agin not sure what is going on I had my son (he's 40 ) come over and help this old man and take a look and he did same as I did and with my old skreem fobs work and with the new one they don't we don't get why but we both had the same things happen so till I talk to rob to see what's up ???
