Old Apr 4, 2017 | 06:15 PM
Ksmi87's Avatar
Ksmi87
Default Re: What RPM is best shiftpoint - manual 6speed
The clutch on our Crossies is hydraulic and limited to a slow engagement. You simply cannot "pop" it. So except for burning it with a partial engagement you won't hurt it or the engine.
But to your questions,,,;
First, you won't hurt the clutch doing normal takeoffs in second gear. A lot of us do it.
Secondly, shifting at 2K RPM is wimpy. That is a tight short stroke V6 under the hood. With a flat torque curve that goes from 1500 RPM up to the rev limiter at about 5800 RPM. Wind it out.
Try to stay under the 5500 mark or the Rev Limiter will shut the engine down briefly. A bit of a surprise if you aren't ready for it. It's there to protect the engine so let fly. And enjoy.
I wind mine out through every gear but first. Using it only to get rolling. Then wind up to at least 4000 RPM through 2nd, 3rd, and then 4th if you dare. You won't hurt a thing.
Have fun...!
roadster with a stick...like it should be!!!!!
man you just made my week... like I said I'm used to driving anything from Tractor and trailer to stick shift full-size trucks this has been a very good experience so far and I have fallen in love with it.
did not know that about the hydraulic clutch thanks for the info that's exactly what I was looking for!!
