Chrisjlyon
So I resoldered the RCM. No change. I jacked the car and tapped the starter and it fired up. So much for the last guy replacing it. I let it run for a bit then shut it off. Put it back together and now it won't start again. I did change out the fuses to match the manual's diagram. I guess I'll replace the starter before anything else. Also while it was running the radio wouldn't turn on and the spoiler wouldn't go down. Not sure where to start on those. Thanks again guys
Glad you mentioned that, when my RCM had bad solder joints the spoiler would go up on it's own
and I would not be able to lower it with the button. You'd be amazed at how many things are linked
to the RCM I wouldn't put all my money on the starter just yet. keep testing!
