Old Apr 10, 2017 | 09:50 PM
  #176 (permalink)
tleed's Avatar
tleed
Default Re: HOW TO replace headlight bulb. Pictured step by step instructions
I just replaced my passenger side low beam headlight. First bulb on this car. I found this post, but didn't read all the way to the first page where the pics & instructions are until AFTER I replaced the bulb.
Instead, I found another post that referred to this web page that also has extremely helpful pics: https://howtune.com/articles/108-rep...sler-crossfire
I read some spooky posts that talked about removing the front fascia.
However, my experience was pretty easy. I didn't time the process, but I'm sure it took less than 5 minutes. The key was using a long-handled needle-nose pliers with angled handles.
The key to not touching the bulb with my fingers was…not touching the bulb with my fingers. I sliced the package open and removed the bulb with the pliers. Then I re-set the bulb in the pliers for insertion in the car by holding the bulb by the metal plug prongs.
The key to not losing the little wire clip was just carefully unhooking it from the retaining hook. My bulb was the outboard passenger side, which is apparently the most difficult one to reach. Nah, it wasn't that hard. And, yes, I've dropped my share of tiny little parts into blind crevices requiring major disassembly to retrieve. That just wasn't my experience this time around.
Thomas
