Old Apr 15, 2017 | 08:21 AM
onehundred80
Default Re: Stumbled upon you guys while trying to fix my xfire
Originally Posted by Kgalliher519
I had the battery unhooked for a full day. After unhooking the battery for a little bit and resetting the system I will get 2 almost starts and then no crank. This has happened every time that ice tried to start it after messing with something so at least a dozen times.
Does it fit the description of the SKREEM starting? 'Almost starts' could be described as a symptom. 'Starts and stops after a few revs' is the more common description.
