Old Apr 15, 2017 | 10:02 AM
onehundred80
Default Re: Stumbled upon you guys while trying to fix my xfire
Originally Posted by Kgalliher519
Ok. I pulled the rcm to check the 3 'trouble points, they had a good cover on them. When I turn the key the engine will crank to try to start twice without firing up and then on the 3rd try it won't even try to crank. If I disconnect both terminals on the battery to reset the system and try again it will repeat what said before. 2 cranks, no start then no crank
This is the classic symptom of the SKREEM failure.
It is not the RCM, the plastic cover can hide faults, I am not sure what you mean by this. That is like saying he cannot be dead because he has a good suit of armour on.
