Re: Multi-function Switch/Headlight switch replacement?
Can anyone confirm that the Mercedes multifunction switch is an exact match for the Chrysler? My mechanic is saying the plug in is different? Curious if what the actual switch says when it is removed for replacement. Thank you so much for helping clarify!! I really need my right turn signal, it is the only part that doesn't work, I guess the plastic channel is damaged.
