Old Apr 15, 2017 | 10:36 PM
rush549's Avatar
rush549
Default Re: Stumbled upon you guys while trying to fix my xfire
Originally Posted by Kgalliher519
Ok. I pulled the rcm to check the 3 'trouble points, they had a good cover on them. When I turn the key the engine will crank to try to start twice without firing up and then on the 3rd try it won't even try to crank. If I disconnect both terminals on the battery to reset the system and try again it will repeat what said before. 2 cranks, no start then no crank
The solder joints looked fine on mine. Perfect in fact. I re soldered them anyway. That fixed it. Never had another problem.
