Loctite 40482
Apr 20, 2017 | 03:57 PM
permalink
onehundred80
Apr 2006
25,432
651
Ontario
Loctite 40482
Has anyone tried this RTV yet. It would appear to me that you could get the small bead required and not the blobby looking bead that is too big and probably leads to premature failure of the seal. This gets away from the need for the expensive Mercedes tool that uses their sealant. It appears that the sealant tube is reusable if resealed as they say it should be.
With this can you should be able to lay down a small consistent sized bead that just fills the groove without the excess that shows too much when it is squashed out of the joint.
It is sensor safe and appears ideal for our application on the breather covers and elsewhere. At about $19 a tube it seams a good buy.
CLICK
CLICK
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
