Old Apr 21, 2017 | 10:03 PM
Speedy4x4's Avatar
Speedy4x4
Default
Originally Posted by Ksmi87
hey guys - ive searched through the forum and haven't found anything specific pertaining to this question.
Ive got the kenwood new head unit in and a sub box built with an alpine 12 in the hatch compartment -
all that is needed now is running of RCA from head unit and a power wire from the battery for the amp
if anyone else has ran their own power wire, did you go underneath the vehicle and wire the frame rail etc and up through the rear hatch?
or did you all drill through firewall and bury the power wire within the panels of the interior of the xfire?
thanks in advance guys - drive safe
ks
Where are you wanting to put the amp, behind passenger seat?
Or in back?
Make sure you run the rca and power in seperate locations or you chance getting noise interference.
I ran my power wire under battery, there is a rubber grommet through firewall, behind kick panel and under the door silver to behind the seat.
Rca and remote through console and exit out the back bottom of the console to behind the seat.
With the amp behind the seat when I have the window down there is alot of air that runs behind the seat keeping cool, but even with the windows up in winter, even with running amp 4 to 6 hours with it has not been to hot, just warm.
Pretty easy to run the rca under console and power through firewall then under the sill
