Old Apr 23, 2017 | 09:21 AM
onehundred80
Default Re: Stumbled upon you guys while trying to fix my xfire
Originally Posted by Kgalliher519
Update. New RCM didn't work, same issue that I was having. Towing it to the dealership tomorrow. Just in case it is the starter i bought my own since it was going to be $900+ through the dealership. They're nice enough to change it out with the one I bought since there's is so expensive. Hopefully this fixes the problem. Don't have any other security issues so not sure how it could be the SKREEM.
The three start and then a battery reset to do it all over again is the classic symptom of a SKREEM failure.
Read up about it here on the forum, just search SKREEM and see, there is one cure if that is the cause and that is a new module. You can buy this module from NeedsWings for $250 and it is plug and play.
Surrendering to the tender mercies of your local dealer will likely cost you much more as they will change everything before they get to the SKEEEM.
Read about the symptoms and lf your problem fits them, buy a SKREEM.
A starter probably costs more. How you settled on a starter I cannot figure out.
