Old Apr 23, 2017 | 12:57 PM
onehundred80
Default Re: Stumbled upon you guys while trying to fix my xfire
Originally Posted by Kgalliher519
I did read through all of the SKREEM threads. My alarm does not go off, car doesn't start at all, and there is no check engine light registering. I had read about removing fuse 9 being a temp fix and that didn't solve the issue (not sure how true it is bit from what I read worked for a few people). When the key is in the "on" position you can here the starter click like it is trying to engage even though the key is not turned. All this leads me to the starter being the issue. Whether it's the whole starter or just the solenoid that's gone bad.
Good luck at the dealer as you will need it.
Tell him about the SKREEM though.
