valley89
Yes, it has worked over 5 years, since I've owned the vehicle. It only stopped working recently.
I always use the remote unlocking, I assume the key will operate manually
If the key will not open the door when inserted and turned then something is wrong inside the lock mechanism.
You do not say if it turns in the lock or not, or even if the key goes all the way in.
Full descriptions of the facts helps us, you know but we can only make assumptions.
