Old May 3, 2017 | 02:39 AM
Mrmiata's Avatar
Mrmiata
Default Re: Automatic gearbox does not shift up unless I let off the gas - any ideas?
Your problem is the max 4400 RPM, holding the pedal down should shift up at about 5200 RPM, but since it isn't getting there, no shift.
I have no idea why 4400 is your limit.
Would that be the same limiter as when your in neutral and rev the motor..?
