Old May 7, 2017 | 09:58 AM
onehundred80
Default Re: Liqui Moly Cera Tec Friction Modifier ?
Originally Posted by No2fast
Hi,
Liqui Moly is a german company since 1957 known for quality products, especially oils and additives. Pricey but prooved stuff. Reviews
https://www.amazon.com/Liqui-Moly-20.../dp/B001CZODH8
In Germany this product is commonly used on high milage diesels. It helps also to reduce the fuel consumption for sure. There are a lot of happy misers here in Germany being proud to save some fuel with the additive (thats maybe the main reason for usage). Gas is very expensive here in Germany, 3 x times more expensive than in the USA.
Hundreds of positive reviews even here, check with google translater
https://www.amazon.de/Liqui-Moly-372...i+moly+ceratec
Of course, the LM will not repair a mechanical problem - it`s just a ceramic friction lube - but a good one.
Watch this:
https://www.youtube.com/watch?v=Q-7K86w0-_k
"Wagner micro ceramic oil" (also a german brand) seems to have even more ceramic contents than the LM , but i am not sure if too much is too much..
https://www.youtube.com/watch?v=zwNicULSTsk
Steven
Berlin Germany
We have many seat of the pants dyno experts here and I am sure they would swear to improvements when using this stuff. If saving $10 worth of fuel after spending $15 on the additive is what you get then it is not worth it. If the reverse was the case then governments would insist on its use to reduce pollution, except in countries that scrapped enviromental rules and regulations to enable the use of more polluting fuels.
