Old May 7, 2017 | 10:11 PM
GraphiteGhost
Default Re: Car not starting
Originally Posted by MB04XFIRE
Hi, just curious if you managed to fix your starting issue and blown fuse?
I went to take my car out for the first time this spring and had a similar issue. It started fine about a month ago but when I went to start it today the starter clicked when I turned the key but didn't crank over. And then I also noticed that the dome lights were out.. Looked into the fuse box and noticed fuse 7 blown. 5 amp fuse. Put a new one in, tried starting again and still just got a click but the fuse didn't blow.. Figured perhaps the battery was low. Put on the battery tender. Will try again later today or tomorrow and see what happens then.
I do not think a 'battery tender' has enough charging current to fully charge your battery. In fact, the two tenders I have caution not to try to charge a low discharged battery.
