Old May 9, 2017 | 05:43 PM
BibaResto's Avatar
BibaResto
Default Replacement lug nuts situation
I'm toying with going hubcapless . Consequently I am looking for more 'interesting' lug nuts.
Probably the same on all XF's but the bolt (not really a nut) is 11mm x 1.50 x 45mm. I might be incorrect on the latter length since I measured from the upper edge of the taper to the end of the bolt. Bolt alone is 38mm.
I've not found any 11mm lug nut bolts. I suspect - and this makes absolutely no sense - that they are listed as being 12mm. I can assure you that 12mm will not fit into a 11mm hole.
What gives? Or are XF's the only cars which use 11mm lug nut bolts and are a fortune for each one?
