Old May 11, 2017 | 01:07 AM
Red Runner's Avatar
Red Runner
Default Re: Replacement lug nuts situation
Originally Posted by BibaResto
I've not found any 11mm lug nut bolts. I suspect - and this makes absolutely no sense - that they are listed as being 12mm. I can assure you that 12mm will not fit into a 11mm hole.
What gives? Or are XF's the only cars which use 11mm lug nut bolts and are a fortune for each one?
Looks like you have a very unusual problem because XF lug bolts ARE 12mm x 40mm (1.50") long. You need to recheck your 11mm ? bolts. Have you tried using a brand new 12mm bolt?
