Old May 15, 2017 | 10:16 AM
  #5138 (permalink)
JEFASOLD's Avatar
JEFASOLD
Originally Posted by Shaneth
Had a good day;
1, Replaced the interior rear view mirror, (the silvering was degrading around the edges on the old one?)
2, Replaced the wiper blades.
3, Removed the crappy under-hood insulation & replaced with shiny new alloy / foam replacement.
4, Removed the stock MAF housing & replaced it with the larger 74mm housing (keeping the stock sensor).
Feels good, next weekend? Oil catch can !!!!!!
I just finished replacing mine too but the foam is a gloss black. I purchased this online someplace and it came with a break off disposable blade and a roller. What I did was cut it to fit, even cut slits to fit factory hold down tabs, then cut an X in the backing put it in place then slid my hand under and pulled the backing off in 4 quarters, then used the roller. Will also post some pics when I finish everything.
