Thread: HVAC fan issues
Old May 21, 2017 | 11:26 PM
onehundred80
Default Re: HVAC fan issues
Originally Posted by maggy55
Okay my HVAC fan speed control seems to change speed on it's own, not at every speed level, but at a couple of them. It will speed up and slow down. If I jiggle the rotary dial I can get it to change speeds as well. I have removed the unit and done the repair suggested by CL770. I have also replaced the fan motor resistor. Neither fixed the issue. Any other ideas ? Is there a way to clean the rotary switch ?
There is a fix that was posted by a new member some little while ago. Basically he said that the connection of the front plate and the PCB behind it was poor and caused trouble. I'll look for the fix and post it in this post.
Try this fix. CLICK
