Old May 24, 2017 | 12:56 AM
onehundred80
Default Re: Another crank but no start dilemma
Originally Posted by Davgord
OK, a little more of an update...the fuel pump fuse is pristine as are the relays and solder points (no debris, no heat marks, intact solder). Remembering that this is a 14K mile cream puff. The case for the pump itself seems to be getting stronger unless I am missing something.
As far as the relay itself goes...As I look for a replacement on line, all I find is a 250 dollar unit. All of the other relays indicate that they are not compatible with the 05 crossfire srt6.
You could check that there is power at the pump before you buy another one, a simple check to do and it could save you $$$$.
