Old May 26, 2017 | 07:13 AM
GraphiteGhost
Default Re: Air bag disable light separated from the bezel.
Originally Posted by Kurtp13
I don't think it's disconnected. It's just loose from the bezel according to the previous owner. I could get a surprise when I open up the trim to access it, but I doubt it. So no electrical connections should be necessary.
Once again, and done. It is a wise move to disconnect the NEG battery cable before doing work in or around the SRS system. George recommended also turning on the iggy to further drain the electronics. Hope you have no trouble that's for sure.
