Old May 26, 2017 | 08:02 PM
gragonese's Avatar
gragonese
Default Re: Strange electrical issue
Originally Posted by Steve Jr
Your problem seems to be pointing to the brake light switch. Does the "reminder" start beeping, with your foot on the brake, the light switch on an no key in the ignition?
It will start beeping once the selector is moved with a no key in the ignition. However once the brake pedal is pressed with the selector in any other position than off you can heard the fuel pump prime and the vehicle acts as though the ignition is is the on position.
