Steve Jr
What I've suggested, is as far as I can take you on that. But what might help is, if you look at the back of the trim ,that light is held in place by 4tabs. 2 on the top an 2 on the bottom an the light an the piece it's attached to, will separate from the rest. If you use a flat screwdriver, gently pry down on one of the tabs, then the other. I used the top ones. Then you can push it out gently, an separate that piece from the rest of the bezel. That my provide you a better look at the clip.
I was able to find the release point on the backside but this cigarette lighter connection is a tough one for me.
I can see that it slides horizontally off off the socket and 180 just confirmed that with a photo, but I can 't find the release point(s)
Thanks
