Old Jun 21, 2017 | 03:18 PM
TheThomaswastaken's Avatar
TheThomaswastaken
Default Re: Warning will robinson !!! - kyb shocks
The rear suspension is dropping all that way because the shocks, but what is pulling it forward? Probably the sway bar. If you had only one jack, you could remove the sway bar bolt to prevent the tire swinging forward. Then the tires wouldn't swing forward, BUT getting the swaybar bolts back in place might be an experience.
