Spare Tire
Jun 28, 2017 | 12:27 PM
permalink
ZH SRT6
May 2010
74
Holland, Ohio, USA
Re: Spare Tire
Quote:
JohnGiaccio
I found this listing today on Ebay for 01 02 03 04 MERCEDES C230 C240 SPARE TIRE WHEEL RIM 205/55R16 16" OEM - will this fit on our Crossfires?? Thank you.
Hi John -
I think you must be pointing to this eBay listing, right?
01 02 03 04 MERCEDES C230 C240 SPARE TIRE WHEEL RIM 205/55R16 16" OEM | eBay
My suggestion is that you
NOT
go with this one, because it is a messed up example of what you could use. The one pictured in that eBay listing has the original Mercedes folding tire replaced by a
regular
tire which will take up much more space (and probably weigh more) than the folding temporary spare which Mercedes provided in some cars (including in some SLK siblings of Crossfire).
Much better choice could be
#933 MERCEDES C230 COUPE 02-05 SPACE MASTER 15 SPARE WHEEL RIM TIRE 2034012002 | eBay
Although you also need to note the warning on the temporary spare wheel (and in the earlier post by Squirrel Crusher) that the regular lug bolts are
too long
, and must be replaced when mounting this temporary wheel with the special shorter bolts which were supplied with the spare assembly when the Mercedes was new.
Also, as in my earlier post in this thread: these 15" wheels fit fine on N/A (Normally Aspirated) Crossfire, but
not
on SRT models with bigger brakes. The SRT requires a 16" version, as supplied on some second generation SLK cars, the R171.
ZH SRT6
View Public Profile
Send a private message to ZH SRT6
Find all posts by ZH SRT6
