Thread: DIY car ramps
Old Jul 14, 2017 | 09:43 AM
dedwards0323
Default Re: DIY car ramps
Saw some 16,000 lb Rhino ramps on sale for $60 and purchased them. Seemed cheaper and easier and seem to have good clearance.
Originally Posted by mariontr
How did those Rhino plastic ramps work out. I'm thinking about doing it..
I've had a set of the Rhino Ramps for probably 6-7 years now. But mine are 8000 lbs capacity (Product 11903) and I don't think Rhino Ramps even produces this version anymore. Looks like they start out with 12000 lbs design & offer the 16,000 lbs version as the upgrade.
I've gotten considerable use from my set and hardly ever use the old metal ramps I have. Main difference - the angle of approach on the Rhino Ramps is shallow enough that today's cars can climb the ramp w/o rubbing. The Rhino Ramps are also much wider to accommodate today's low profile rubber. My old steel ramps had much steeper inclines (due to a higher overall lift) & I had to make a couple of transition pieces to enable the cars to go up the ramps. But the metal ramps have inclines that can be removed which is a plus for working in & around both front & back of tires. If I need that overall clearance, I get the steel ramps out. For changing oil by draining from the underside and/or replacing the steering stabilizer, the Rhino Ramps work great!
